B16 in EG, iacv problem
Discussion in 'General Tech and Maintenance' started by tgreaves, Aug 8, 2005.
  1. tgreaves
    tgreaves Junior Member
    Baltimore, MD
    I have a 94 civic VX and I did a b-series swap into it.. I used a 94 GSR engine harness and plugged it up to my stock 94 civic vx main harness..
    For some reason the iacv isnt working.. It worked fine on my other setup(89' crx) but not in this one.. I know the iacv works since I tested it.. Is there any special re-pinning I have to do or anything when using these 2 harnesses.. I am going to trace the wires back to the ecu to make sure they are correct but I just wanted to see if anyone knows off the top of their head what the problem might be..
  2. tgreaves
    Baltimore, MD
    Also what color wires go to the iacv and what color wires go to the EVAP purge?
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    IACV is BLU/YEL and YEL/BLK
    Evap is RED and YEL/BLK
  4. tgreaves
    Baltimore, MD
    Thanks.. Ill check it out tonight..
  5. tgreaves
    Baltimore, MD
    I got it fixed.. The damn iacv plug was hidden underneath the intake manifold..
  6. phyregod
    phyregod !!YTINASNI
    Central Texas
    Plug it in, Plug it in! :doh:
  7. tgreaves
    Baltimore, MD
    Now thats just some funny stuff there.. :)
