b16 in need of help
Discussion in 'HYBRID -> EG-EK / DC' started by allgo, Nov 3, 2003.
  1. allgo
    allgo Senior Member
    i have a b16 that is make is a popping sound through my stock exhaust. y is that? will timing make that happen??
    also, when i am driving my car normally, the car seem to want to break down, is this also due to timing? some guy just change my timing for me and im not sure if its timed correctly. one example, im driving normally and suddenly i see my tach jump up than down(from 2500 to 4000+ than 1000 and after that i need to build up speed again). i seen it jump up b4 and thought its just the vss but i never seen it go down. when it jump down, i my car felt like shit and i can barely drive the car then it goes back to normal after the bogg. i am scare to drive it. whats going on.?
    did i blow up my motor???? HELP
  2. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    bad ground or alternator dead/battery dying for the needle jumping.
    change your dizzy cap, check plugs, wires, timing, make sure you have all grounds from the motor to the chassis.
  3. allgo
    allgo Senior Member
    i was getting cel 20. then it turn off. will that be the cause??
