are the b16 injectors the same as the 88-91 civic si injectors....and what other honda or acura injectors can u use on a b16 can u use acura legend injectors too???
Dont be mislead byt hte size of the engine in relation to the size of the injectors, I believe all injectors are the same size from 88-95. Now, the only difference being OBD versions. Ok, with that said. Good Luck
