B16 Integra Swap
You wouldn't need anything, everything you need is either on your car or comes with the engine, basically just swap over your wiring harness and mounts, plug in the new ecu(if it comes with the ecu, if not get a p30 ecu), transfer the tranny, linkage and axles to the new engine, run vtec and knock and away you go.
i wouldnt put a b16 into a teg.. .. you wont feel much of a difference.. i'd just find a GSR or b16 tranny to swap it.. just that makes a huge difference with the LS because the LS gears blow goats
