B16 Into a 2003 Honda Civic EX Coupe?
Discussion in 'HYBRID -> EP / DC5' started by alex_the_hipple, May 22, 2005.
  1. alex_the_hipple
    alex_the_hipple Junior Member
    OK,
    I want to do some sort of swap into my 2003 Honda Civic EX Coupe. I was wondering if I would be able to put a B16 from a 1999-2001 Honda Civic SI Coupe into my car. I don't really want to hear a lot of the smart answers that I've been reading so far (i.e.; you can fit anything into anything if you have the money) because all I'm looking for is information on how to do it. If anybody has any real information on this or could even simply point me in the right direction I would appreciate it immensely.
    Thanks,
    ALEX
  2. MXDesa
    MXDesa Senior Member
    Queens, New York
    To be quite honest, those engines aren't easily interchangable. After 2002 honda engines began rotating in the other direction. Its not the biggest problem in the world but its hard to install it and to wire it. If its a opinion you want, i would suggest you look into a k-series engine. It will be a lot easier for you to get done. Good luck :)
  3. jamesA
    :withstupid:
    K20 would suit you much better, and it has more torque than an a2.
  4. VTEC_CBR
    VTEC_CBR Senior Member
    Virginia Beach
    :withstupid: easier to do, and more torque.
  5. jdm2gen03
    jdm2gen03 Senior Member
    not sure were ur from but if ur from california like me then u cant put and older motor into a newer car because of smog reasons. but everyone else is right go K- motor. you will be alot happier with that then the b16
  6. jdmeg6
    jdmeg6 Senior Member
    So Cal
    Agreed! K-Series all the way in this case. The B-Series would just be a pain in the you know what.
  7. jdmlovingcrx
    jdmlovingcrx Member
    cincinnati
    if you want to put a b16 in it you might as well be a pimp and get a cl type-s motor and try to fit that shit in there!
    j-series all the way! :worthy:
  8. phunky.buddha
    Dallas / Fort Worth, TX
    K = makes more sense, but the B is easy too. You just won't find any ECUs on the market to run it (maybe 2001 ITR), and there aren't any mount kits for it either.
