b16 into eg wiring
civic84
hi guys, ive just droped a b16a into my 94 eg, im in the process of changing the existing b16a wiring from obd0 to obd1 to match my cars normal wiring. has anyone else done this or does anyone have any diagrams.
p.s im in need of a b16 obd1 dizzy and a p28 ecu.
cheers guys.
Cheers? Where are you?
The easiest way I can think of is swapping the distributor, injectors, and alternator over to the OBD I versions, and using the wiring harness in you car, along with the P30 ecu.
get the guts from a obd1 civic dizzy, they will swap into your b16 housing, they are alot easier to find.
obd1 distributor internals do not fit in the obd0 housing.. ;)
Use your 94 eg's engine harness and extend vtec wiring and Intake air temp wires to reach on the b16. Then either chip your stock ecu to run the b16, get a chipped p28 from HA Motorsports for the b16, or pick up an obd1 p30 (good luck finding one)
