I want to swap out my built up ex motor for a b16 and i was wondering who has done it and what other then the motor,ecu,axles,and motor mounts, for this swap and what problems will i run into. the motor wqill be going in to a 92 4dr civic
thanks
i dont think youll have any real problems, and as far as parts it sounds like your headed in the right direction, pick up a timing belt, water pump, and thermostat before you put it in.
