B16 longblock, exhaust, + more * NEW ENGLAND*
Discussion in 'Parts: For Sale/Trade/Wanted' started by HatchSpeeD, Jun 2, 2008.
  1. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    9/4/08 **UPDATED** More things sold & more added!
    1) OEM dual core radiator & fan - $50
    From a Del Sol VTEC (B16). It's seen better days but still works fine.
    2) Civic/Integra short shifter - $50
    Don't know what brand it is but it feels heavy, heavier than my stock gsr so it might be a good quality steel one like S2 or blox.
    3) OEM EG B-Series mounts -
    The main 3, driverside, passenger & rear.
    - $20 each or $50 for all three.
    I also have the front lower transmission mount with ES poly insert. All 4 for $75 + shipping.
    4) AC from a Del Sol VTEC (B16) - Make offer
    I have most of the components. Radiator with fan, wiring, compressor, hoses, lines, canister, bracket/mount etc.
    5) Stock B16 intake/box from a Del Sol VTEC (B16) - Make offer
  2. mikeyg323
    mikeyg323 New Member
    does that include b16 tranny too?
  3. ls ef
    ls ef New Member
    Nah it says longblock....If it included tranny and all it'd be a lot more.
  4. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    Thanks :thumbsup:
    If your looking for a full swap, your looking at close to 3 grand with shipping from hmotorsonline.
  5. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
  6. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
  7. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
  8. ep3moschini
    ep3moschini I R T3H NO00Bz!
    Northbridge Ma
    I might grab that motor in a week or so from you would you do 700 picked up?
  9. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
  10. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
  11. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
  12. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
  13. ha_neon
    ha_neon New Member
    would you sell the intake manifold alone?
  14. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    Sorry, trying not to part out the motor parts. If anything changes i'll let you know.
  15. ha_neon
    ha_neon New Member
    how about money plus a trade for my JDM B16A intake manifold and a fuel rail?
    I just figured since it's all ready missing the fuel rail and TB it's not much further from missing the whole intake manifold. just sell it as a short block.
  16. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    Why do you want the trade manifolds? What's the difference?
  17. efhondakid
    Akron-Canton, Ohio
    OBD0 has these shitty looking air boost valves on them that do nothing. OBD1 doenst have them, looks a lot cleaner.
  18. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    I know about the obd differences but I would assuming it would be an obd-1 trade which to my knowledge is no difference. Anyway, just looking to sell this stuff.
  19. ha_neon
    ha_neon New Member
    the B16A3 is OBD-I, has the MAP sensor attached to the throttle body, and has a purge control solenoid. The JDM B16A intake manifold doesn't have the purge control solenoid system since they don't use the in japan, an the map sensor is attached to the fire wall (as in the JDM SiR-II's) I would need the B16A3 (Del Sol) intake manifold to pass the state referee inspection in California. So in other words to legally swap a JDM B16A into a civic in CA I need that exact intake manifold and throttle body, any other state you could run the JDM intake manifold and throttle body without any problem, like my best friend in texas who has the same setup.
  20. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
