b16 machining
Discussion in 'Engine Building' started by jdmracer, May 26, 2005.
  1. jdmracer
    jdmracer Member
    yo i bought a b16 from jspecautosports, cracked it open and my cylinders are out of round and also tapered. so i need to bore it out n i was wondering how much can io take off without runnin into problems? im plannin on runnin ctr high compression slugs, and itll be n/a. n how much do u think that will cost me to get it bored out and also to get the pistons, everything total together. any help is appreciated, thank u.
  2. HollowJDM
    HollowJDM Senior Member
    ive heard 20 over is a good bore, dont think its max but someone told me it should take careof problems and its safe to avoid problems, but im not a rebuild expert so, dunno
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Ask a good machine shop- there's no way someone online who's never seen your block, let alone measured the damage can tell you how much you need to bore the block to clean things up.
  4. sohcslammer
    sohcslammer Senior Member
    Bay Area
    Ummmm... 85mm should take care of it.... :D
  5. D See 2
    D See 2 Senior Member
    Baltimore, MD
    the honda manual reccomends a max bore of 81.25mm but do as you wish.
  6. jdmracer
    jdmracer Member
    yo calesta i wasnt asking how much to bore it out to take care of my problems cuz i have measured my block and i know my problems, i was asking what is the most u can bore it out without weakening the already weak cylinder walls of the open deck block
