b16 New dizzie help....
Discussion in 'Civic and CRX - EF' started by Brian1991, Sep 23, 2009.
  1. Brian1991
    Brian1991 New Member
    Philadelphia
    so here it is my dizzie went bad and i got a brand new one right, but i was in such as rush when i took the old one off i forgot to mark where the rotor was, stupid right, theres two ways it can go in but if i put it in wrong ill either be 180 degrees in or 180 degrees out, anyone know the easiest way to figure this out, and i know theres a timing notch and dots by the pulleys but i can barely see them, someone please help. i dont want to mess up the timing
  2. sleeper88
    sleeper88 My mom thinks i'm cool
    Parkesburg, pa
    I dont think it matters. There is a notch in the cam that distributor goes into.
  3. Brian1991
    Philadelphia
    SLEEPER88- where abouts in parksburg are you from im up there all the time my sister just bought a house out there im from downingtown,
  4. BlackFrog
    BlackFrog Neighborhood Lush
    North Freakin' Idaho
    you cant be off when installing the distributor. those 2 notches are offset slightly to one side. youll either force it in wrong and destroy something, or itll slide right in correctly. just take a look at the slots that it slides into, youll see how it goes.
  5. sleeper88
    Parkesburg, pa
    I live like a min from the walmart at route 10 and 30.
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    theres only one way the dizzy can go in there pal...
  7. Brian1991
    Philadelphia
    yeah i figured it out right after i posted the forum about the tabs being offset, but thats alot ppl for posting, an oh how i hate a wanna be gangster, and you can always tell who they are ....OK PAL.....
  8. Brian1991
    Philadelphia
    SLEEPER88- yeah my sis lives on octorara road like 2 sec from 10 n 30 crazy huh, its a small world......maybe ill see you driving around out there.
  9. blasterman87
    blasterman87 New Member
    not true, i put mine in backwards after my swap, didnt start so flipped it over and boom. fixed
  10. Ronny Cage
    Ronny Cage DaughterTestedMomApproved
    south jersey
    well theres only one right way lol.
