b16 on LS tranny?
Discussion in 'Engine Building' started by vtecsi95, Oct 17, 2002.
  1. vtecsi95
    vtecsi95 Junior Member
    Miami, FL
    I currently have an b18b1 LS motor and tranny in my 95 DX sedan. I wanna put a b16 motor on the LS tranny. Will this cause any problems? Is this bad? Should I change anything like the oil pump, or any other parts? The guy who would do it for me said it would be fine. I just wanted a second opinion. :blink:
  2. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    It should fit okay, but why?! That's gonna be pretty frickin ghey..see the LS trans is real long, not great for acceleration. But the LS motor kinda makes up for it because it has a great torque rating for a honda engine. But the B16, well that has high HP but LOW torque..so that thing is gonna be a frickin slug! You'll never get going!
  3. B16
    B16 Super Moderator VIP
    yay area, CA
    well, you're gearing would be all messed up... the b16 is made for high revs, thats where its power is, different story with the ls motor... i would not recommend it, but it will mount on there
  4. vtecsi95
    Miami, FL
    So you think I should just stick with my B18? One thing I thought about was since the Ls has alot of torque is that it would be more preferable since my cars a 4 door and I would probably need more torque than actual HP to get it moving.
  5. B16
    yay area, CA
    yes, if you have an LS, you should boost that biatch :)
  6. djextremity
    The B16 is cool and all, but you really need a tranny with shorter gears for that thing to make a difference in your car. The LS is a good choice for your car, because it's got moderately good numbers, and it's already in your car! Plus, for near the price of the B16 (maybe a grand more), you can turbo that thing, and with just maybe 6psi, you'll be pushing HP similar to/higher than the B16, and some MONSTER ass torque on stock internals. Just a thought..
  7. pissedoffsol
    a 4 door is not much heavier thana coupe dude.
    keep the ls. a b16 will set you back 2500.
    your car wont be noticably faster.
    2500 is a good portion of a small bolt on turbo kit say 6psi greddy kit.
  8. djextremity
    isn't that what i said..?
  9. knowledge
    knowledge Senior Member
    Beale AFB, CA
    With 6psi on the LS motor depending on the turbo he will be pushing HP near an H22. That is without an intercooler too! But like I said depending on the turbo you use.
