b16 or gsr head
xaero
Member
i am planning on building a ls vtec engine, and i heard that a gsr head will out preform a b16 is this true? how would a b17 head preform compare to a b16 or a gsr head?
last i knew there was no such thing as a b17... but if you want ls/vtec do a b16 with ITR cams...or just get an ITR head.
[post=371159]Quoted post[/post]​
B17 = 92-93 Integra GSR (USDM only)
The B17 head is basically the same as the B16 head.
The B18C1 head will give you slightly higher compression because of its smaller combustion chambers, and if you use the dual length intake manifold and are able to tune the IM changeover point, you get a fuller torque band through your mid range.
derr sorry i was thinking Civics. Dunno why I keep forgettin about integras :)
Beyond an increase in compression, the B18C1 head also has larger quench pads which are extremely important in preventing detonation / running cooler and getting more complete combustion.
