b16 pistons in a ls block
Discussion in 'Civic and CRX - EF' started by ls/vtechatch91, Nov 16, 2006.
  1. ls/vtechatch91
    ls/vtechatch91 New Member
    washington
    ok i have a set of b16 pistons and im wanna put them in my ls/vtec.. i also have a b16 head..... will i have enough valve clearance to use them? and what wrist pin would i use???
  2. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    yes if the pistons AND rods are b16 you can. use the set of wrist pins for the b16.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    No. Do not use the B16 rods. If you do, you'll have a really super low compression LS. The stock rods fit. If you're worried about the valve clearance (will be ok with stock cam timing and stock cams), use clay to check your clearances. The stock wrist pins work fine.
  4. ls/vtechatch91
    washington
    okay so im going to have the b16 pistons but on the ls rods and use the b16 wrist pins right??
  5. brian11to1
    brian11to1 Senior Member
    I like your sig dude... you should get to wiping...
    Like Calesta said, use the LS rods especially if you're using an LS crank.
  6. turbo sol
    yeah sorry about that. had the rest of the info right tho. thanks for the correction.
