b16 pr3
Discussion in 'ECU's, Electronics, and Tuning' started by vdubber, Nov 1, 2003.
  1. vdubber
    vdubber Member
    i have an obd 0 pr3. my vtec i have no clue where that kicks in, but my rev limit is at about 7400 ish. i thought i was able to rev to 8200. i want my 1k rpm back. also if it is a manual and i do chip it, say the spoon/mugen program, and the vtec coms on at 4400, and there is no rev limit, if i go above 8200, is there still a fuel cut off because i dont wana have valve float/binding or broke valves and pistons. any suggestions
  2. ChrisSiR
    ChrisSiR Senior Member
    i have the same motor and ecu, my rev limit is at 7800 and vtec kicks in at 4100....
    is this true about the 8200 rpm rev limit?
  3. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    are you getting a check engine light?
  4. R.E.Developement
    R.E.Developement Import King of Irvington
    yo homey u got a automatic ecu. if u dont believe me open the top part of the ecu andlook at the smallcircuit board if it says AT its automatic. if it says MT its manual
  5. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    What's the last 3 digits on the ECU part number...
    Like - 37820-PR3-???
    That will tell you what it is supposed to be.
