B16 rear mount Q
Discussion in 'HYBRID -> EG-EK / DC' started by Hpowered1, May 6, 2006.
  1. Hpowered1
    Hpowered1 Junior Member
    I had a b16 put in my 94cx and the shop that did it had an integra rear bracket and used that one because the one I had was bent. However, only one of the two bolt holes lined up and they said it was because I needed the rear del sol bracket to make it bolt up right. The only thing I can think is it was an LS bracket?? So would the GSR one work as well as the del sol one?? Thanks for the help
  2. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    Anyone one of those B-series bracket should have worked. Basically any 94+ integra bracket should work. The one you have must be from something else or the mechanic is an idiot.
  3. Hpowered1
    so could it be from a 90-93 integra?
  4. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    I think that one is different from the 94+
    That bracket is a BITCH to get the bolts in from inside the engine bay/under the car.
    I have only 1/2 bolts there too after changing my clutch :cry2:
