well just replaced tps, no more code 7, no codes at all...idle surges 1100-800 rpm, revs to about 6500 rpm. I unplugged the iac while it was running to do the fix erratic idle thing and nothing happened, does that mean a bad iac?
where can i get one? went to my d15 and looks like the shop used that one cause its freakin gone...couldnt find one on ebay, honda has em for 99-00 si's but they're $180 and i'm sure they're the wrong one...fuck!
Instead of just buying a new IAC outright, try cleaning the one you've got. Pull it off, saturate the inside with Brake Cleaner, let dry, reattach. Most times, that will cure IAC probs.
