B16 Route.
Discussion in 'HYBRID -> EG-EK / DC' started by nealo, Apr 8, 2003.
  1. nealo
    nealo Senior Member
    i decided to finally ditch the ls route and went on towards the b16 idea. problem is i live in so. cal. i wanted a b16a3 as those are the same obd but theyre too damn hard to come buy. the sir II also came to mind but it being jdm negates the idea of it being a daily driver because i dont think jdm engines pass smog in cali. my final resort was the b16a2 but its obd2. will this engine pass smog in cali? i have an 94 si and i still want to have vtec. or should i just go back to the b18b1 so i can pass smog with my swap?
  2. E_SolSi
    you CAN pass smog with a JDM engine ... you just need to make sure you have all the correct emissions equipment installed and working properly
    the B16A2 is also fine .... again just make sure all of the emissions equipment is there
    basicly as long as the engine is the same age or newer and all of the equipment is there you are all set
  3. oakraiderz2
    oakraiderz2 Junior Member
    What equipment would that be?
  4. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
  5. nealo
    nealo Senior Member
