B16 SiR into EJ9
ukcoupeman
Hi Everyone, I just got a new engine & gearbox for my civic coupe, just need a few tips about the swap!
I've got a B16 SiR motor with a YS1 LSD box, (& I got the mounts, wiring, driveshafts, ecu, gearlinkage, etc!)
I'm going to put it in my EJ9 Coupe (1996)! :D
Wiring & OBD is not a problem as I'm an auto electrician over here, the main problems i need some advice on are the cable to hydralic clutch (or what i can use?) I want to keep the gearbox even if it's a bit of trouble as it has a LSD!
Which driveshafts or combination do i use? & any other MAJOR headaches i might have? :S
Cheers,
Phil.
Salisbury, UK.
Use Integra axles 94+, or any model of Civic that came with a B series motor 92+.
For the cable to hydraulic, you can look at www.hasport.com, they have them.
