b16 speed sensor
Discussion in 'HYBRID -> ED-EF / DA' started by VTECPOWER, Jun 10, 2005.
  1. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    With the lsd b16 y1 trans do I need a vehicle speed sensor from a 90 integra? because the one in the b16 trans is electronic and i need one that is mechanical? can i use one from an automatic integra?
  2. VTECPOWER
    Winchester, VA
    I need this info ASAP as an auction on ebay is ending soon for an automatic vss for a 90 integra.
  3. 88bluehf
    88bluehf Senior Member
    Denton,TX
    i dont think the auto is the same. just rob one from an ls in the junkyard..
  4. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    You can just remove the electronic VSS and plug your speedo cable into your tranny. Thats what I did in my CRX and it works perfect.
  5. VTECPOWER
    Winchester, VA
    Just plug in the cable inside the trans? is there somewhere to put it?
  6. VTECPOWER
    Winchester, VA
    I just ordered a speedo cable because i wanst sure if mine was messed up or not, it seemed as though the end of the cable had been clipped off.
  7. jdm2gen03
    jdm2gen03 Senior Member
    jus curious were u got ur speedo cable from cuz i need one for my integra
  8. VTECPOWER
    Winchester, VA
    ebay stores, it was $26 shipped, "hondapartsunlimited" as the store
  9. Taco15
    Tallahassee Fl
    so you need a VSS? if so i got one. I pulled from a manual. integra. let me know.
  10. VTECPOWER
    Winchester, VA
    Nah, my speedo works now, I also have a VSS if anyone needs one from a 1990 Integra, never used the one i bought, i took off the electrical part of the vss in the lsd trans, the speedo cable plugged right in, and speedo works now.
  11. StarBellieAngel
    StarBellieAngel Senior Member
    San Jose, CA
    i got my speedo cable straight from acura for 10 bucks... lubed all nicely and everything.
