B16 surging help plz
Discussion in 'HYBRID -> EG-EK / DC' started by nicky, May 11, 2009.
  1. nicky
    nicky New Member
    Im running a chipped P28 ecu and have a 1st gen B16.
    All the wires plugged in minus the CKF near the alternator.
    Started the car up and it's surging/bogging.
    Here is a video to show it sounds:
    YouTube - 99 civic B16 swap surging?
    So far I've cleaned my IAC.
    Another ECU, checked all wires.
    Unplugged the IAC plug and nothing happens to the idle?
    Unplugged TPS nothing happens to the motor?
    Unplugged the MAP and the motor turns off?
    Any other information I can provide to fix the problem? Pictures? Videos?
  2. Taco15
    Tallahassee Fl
    check the map and the tps. both plugs are similar and have the same pins. sometimes they get mixed up and you plug them backwards. swap them and see what happens.
    have you tried swapping another ecu?
  3. nicky
    nicky New Member
    YA tried another ecu same thing.
    Replaced IAC it runs now.
    Still getting code 7?
  4. Taco15
    Tallahassee Fl
    check the reference section for the code.
  5. Taco15
    Tallahassee Fl
    throttle position sensor. i dont know if that is for the p28 though. I think that code is an obd0 code unless they are the same. its been awahile since i messed with hondas. :(
  6. nicky
    nicky New Member
    Wat do you mean "If it's for a P28?"
    I think the codes are pretty generic?
    I'll be testing the volts with a multi meter and c if thats the problem.
    Thanks.
  7. Taco15
    Tallahassee Fl
    i meant if its obd0 or obd1. the p28 is obd1 but i was looking at the codes were for obd0. i think they generic though
