B16 Swap 02 Sensor questions
Discussion in 'HYBRID -> EG-EK / DC' started by Lee7pcNOOb, Jul 28, 2008.
  1. Lee7pcNOOb
    Lee7pcNOOb New Member
    Arlington
    I recently swaped a b16a3 into a 97 ek, ive been running a JDM P2T OBDIIa ecu. Im missing the evap purge valve, vtect pressure switch (had to wire it manually and it work), oil crank position sensor (did crank bypass trick) engine run flawless no problem. Im getting ready for emmisions and i was wondering if i need a second o2 sensor for this motor/ecu because i have no check engine light. i had to extend my first o2 sensor wires from the exhaust manifold to the back to the downpipe. and where would this second o2 sensor go? or could i splice the wirefrom the bottom of my car to the sensor thats in the bung now?
  2. R883
    R883 New Member
    The second sensor goes in the cat
    I am not running a secondary o2 eithier
    But i have never done an emmissions test so cant tell u there
  3. Lee7pcNOOb
    Arlington
    o ok thanks i guess ill wire it up once i get my cat
  4. thetunersource
    thetunersource New Member
    hopefully they're easier on you there than here cuz over here you would never pass the visual...
    damn california
