hi i just recenly swapped a b16a into my 91 civic hatch obd0 that already had a 91 b18a1 swap in it an i put the ls distributor on it ( ghetto way) and the ls harness. when i go to turn it on it just makes a clicking noise by the fuse box i'm stumped i thought it was supposed to turn over there is fuel in the lines and also when i take the plug from the wire harness to the fuse box under the hood and touch it on the chassis the engine turns over but the wire gets hot and starts to let a little smoke? the wire i believe is a ground wire for the harness but i don't know im stumped? any help will be greatly appreciated. thanks!
