b16 swap into 99 si questions
Discussion in 'HYBRID -> EG-EK / DC' started by EkSivik_99, Jan 8, 2008.
  1. EkSivik_99
    EkSivik_99 Yea Ho FO SHo
    Newton, Ks
    could someone give me the link to swapn a b16a motor into a 99 civic si iv heard lots of diff stories bout doing it i just need some straight answers before i buy this motor. iv heard the motor will mount up but id have to switch dizzys from my old si motor i need a cheap swap im tryn to sell this car its just to many problems and the sir is a cheap motor to buy also my si tranny is still good but heard the sir is cable and my si is hydrolic could someone please give me some details on what i need to do
  2. Briansol
    what year/obd is the motor? there's about 7 b16a's
    more so, why are you swapping a b16 motor into a car that came with one???? :confused:
  3. EkSivik_99
    Newton, Ks
    i believe its the 92-95 sir obd1 is that right?
  4. EkSivik_99
    Newton, Ks
    oh motor knockn pretty sure bottom end is gone and its hard to find a short block around ks if not that any where everyone wants to sale a long block currently have a ls vtec in it and i dont wanna spend the money on another frankenstine
  5. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if theres a ls/vtec in it already why not sale it like that
  6. EkSivik_99
    Newton, Ks
    sorry u didnt catch on to that post currently has an ls v-tec but its knockn pretty bad so i know rob or crank most of went and im sure with that piston must have messd up the walls so bottom end is gone it has a gsr head on it but i cant find any short blocks or else id go that rout so there for i wanna do a cheap swap which bring me to buyin a b16 92-95 sir motor only my tranny is still good so my ?''s are will the 99 si tranny bolt up to a 92-95 sir and what other parts or complications will i come across with swapn that motor into my 99 si
  7. AHHVTEC
    Alabama
    yes your tranny will bolt right to it,, but if your head is ok, id just buy the cheapest b series i could and put the head on it, just to get the car sold
  8. EkSivik_99
    Newton, Ks
    so ur sayn a 94 gsr head will bolt to any b series short block? without running into any other problems? can any one else comfirm this?
  9. ek_b16
    ek_b16 New Member
    It will bolt right up to any b-series block. The only catch is if its already a vtec block or not. If its a vtec block then just bolt up. If not, you'll have to get the head tap and run a oil line for vtec( ls/b20 blocks)
  10. EkSivik_99
    Newton, Ks
    yea i already have an ls vtec really dont want another one best bet is to find a vtec block thanks guys
  11. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Confirmed.
  12. LS_VTEC
    NJ
    among other things, like upgrading oil/water pumps and the dowel pins must be switched.
  13. EkSivik_99
    Newton, Ks
    yea the motor that just went out was a ls vtec woth 94 gsr block and 94 ls block with polished crank egale rods ctr pistons and b16 internals oil water pump etc and i dont wanna go that way again but thanks for the info ill get some pics up eventually
  14. alEXej8
    alEXej8 New Member
    Hubbardston, MASS
    Periods (.) do wonders in sentance comprehension. I was trying to understand what you were asking to see if i could give you a hand, but I am completely lost. Good luck with your motor though.
  15. EkSivik_99
    Newton, Ks
    one more question Ls arp studs were used on the lsv block (period). will they work on a b16 block or gsr?
  16. ek_b16
    ek_b16 New Member
    Normally if they were stock, you would use the head studs originally for your block. I'm not to sure if I would in this case..
  17. riceburner89
    riceburner89 Banned
    santa clarita CA
    LOL why are you swapping a b16 into a car that already has a b16:ufucktard:
  18. EkSivik_99
    Newton, Ks
    have u read anything i wrote or anything any one else wrote ur a fucktard for not payn attention.that question has been asked and answerd. if u anit got nothing positive to say bout my questions get off my thread.
  19. hondapowerb16a2
    hondapowerb16a2 New Member
    check ebay they always have blocks for sale
