B16 swap prep work!
jspecgarage
Ok I am getting ready to put a B16A1 into my 1991 EF hatchback! I want to know replacement parts I should do? Gasket, blets, water pump?ETC???
Here ya go! :thumbsup:
• Replace the water pump & thermostat
• Replace the timing belt and timing belt tensioner
• Replace Cap, Rotor, and Spark plugs
• Adjust valves
• Replace cam end plug
• Replace valve cover gasket and spark plug seals
• Replace fuel filter
• Replace PCV valve
A new oil pan gasket, and front and rear main seals wouldn't be a bad decision either. In total they are like 45-50 from the dealer and might save you from some oil leak problems.
