I am just starting to get back into hondas after being in Japan the last 3 years. I have a 94 Civic EX and just bought a JDM B16 complete w/ ecu, half shaft, and tranny and also bought Avid mounts and hasport axels.
I want to do a med build and have purchased Skunk 2 Stg 3 cams, Super tech springs/ retainers, Skunk 2 Intake manifold, Blox 70mm TB, Super tech nitrade valves/ valve guides/ valve seals, Buddy club cam gears, Skunk 2 cat back exhaust, DC Sports 4-1 header, Exedy stg 1 clutch and lightened flywheel, ARP headstuds, Golden eagle fuel rail. I am still looking for more stuff but would like to stick with Stock bottom end if possible.
My questions:
What is recommend as far as head gaskets, have been looking at thinner ones made by buddy club or cometic?
Timing belt brands recommended or just a OEM Del Sol same as water pump?
Should I upgrade injectors, was thinking about RC 310?
I would like to run a hondata s300 chip for ecu, anyone have much experience with it?
Any other recommendations would be appreciated.
My questions:
