B16 swap
Discussion in 'HYBRID -> ED-EF / DA' started by 1989civichatch, Jan 13, 2008.
  1. 1989civichatch
    1989civichatch jdm
    Derby, Kansas
    Hey i was wanting to know if purchasing the lsd tranny w/ the complete changeover on hmotors is worth it, i have heard that having the lsd tranny makes the gearing extremely short, should i go ahead and purchase it or not?
  2. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    LSDs do not shorten the gear ratios. That would be the final drive or the drivin gears you'd have to change. LSDs help you put more power to the ground by giving power to the wheel with most traction, rather than an open diff that puts power to the wheel with least traction. Think of posi-track, if you come from a dometic car background.
    I can't speak for hmotors.
  3. 1989civichatch
    1989civichatch jdm
    Derby, Kansas
    so go with the lsd for an additional $300
  4. YBLEGAL
    NW Indiana
  5. 91_civic_si
    91_civic_si New Member
    Wasilla, Alaska
    get the non lsd and install a quaife lsd. It is way better than the factory one.
  6. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    The stock lsd is fine on stock engines, you dont need to spend 1000 bucks on an aftermarket diff unless you like wasting money.
  7. 91_civic_si
    Wasilla, Alaska
    The stock diff is a plate type that wears out easily.
  8. 1989civichatch
    1989civichatch jdm
    Derby, Kansas
    i think im just goin to go ahead and get the lsd tranny
