B16 Swap
Discussion in 'HYBRID -> ED-EF / DA' started by VTECPOWER, Jun 8, 2005.
  1. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    Ive gotten almost all the parts needed for my b16 in my 88 crx dx, all i need now is the 90 integra throttle cable, does anyone know where I can buy this? Ive check autozone/advance/carquest and also a local honda dealership and he said he couldnt get it because he doesnt have an acura parts book, does anyone know where i can find this throttle cable besides a junk yard? This is the last major part that I need, or is there a way I can still use the dx throttle cable?
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    I got mine from a dealer. You could check hondaautomotiveparts.com for the part # and give it to the person @ your dealer....or just order it online. Its not a big deal, and you'd probably save some money going to a junk yard and finding one.
  3. VTECPOWER
    Winchester, VA
    Um...... that website has honda parts, I didn't see any acura parts listed.
  4. ripperbone
    ripperbone angry bear
    Oklahoma
    I just used my stock crx throttle cable and it works just fine
  5. VTECPOWER
    Winchester, VA
    Are you sure? From what Ive heard I need the 90 integra throttle cable, can someone clarify this?
  6. CoreyR
    CoreyR Senior Member
    you could make a custom throttle calbe bracket for the intake manifold. otherwise you need to use the teg cable cause the CRX is too short.
  7. kyleirwin
    kyleirwin Retired OG
    Vegas
    http://www.acuraautomotiveparts.org/ for genuine acura parts. i couldn't find the throttle cable in there though, maybe you'll have better luck. if not, call them up and ask them for it. you'll also probably get a better deal ordering it from them rather than your local dealer.
  8. brian11to1
    brian11to1 Senior Member
    you can use the throttle cable from youre dx, ef9civicgen4 did so. its looks tacky, but works. otherwise, call acura in your area and request the part.
  9. VTECPOWER
    Winchester, VA
    what kind of bracket can i make and what does it look like?
  10. ripperbone
    Oklahoma
    it's not to short.
    heres a picture of mine, you can kinda see it, but I have plenty of room to spare on my throttle cable. also I have a modified throttle cable bracket
  11. VTECPOWER
    Winchester, VA
    So do i definately need to make a throttle cable bracket? If anything wouldnt the DX throttle cable be too long?
  12. ripperbone
    Oklahoma
    my cable is too long, so that why I have it routed around the master cyl. I have another bracket that I was working on, let me finish it and I hit you up so I can send it your way
  13. VTECPOWER
    Winchester, VA
    Alright man, thanks, I saw that someone else had wrapped the cable around the master cyl then to the throttle body, but that sounds great, let me know asap, as my engine harness has been shipped out from rywire and should be here by the end of next week.
  14. ripperbone
    Oklahoma
    i will finish the bracket this weekend.
  15. VTECPOWER
    Winchester, VA
    Sounds good, hit me up when your done.
