b16 tranny
Discussion in 'Integra' started by oopadoo, May 11, 2011.
  1. oopadoo
    oopadoo New Member
    Is a 99 jdm b16 tranny compatible with with my 94 ls block
  2. oopadoo
    oopadoo New Member
    I'm trying to build an ls vtec
  3. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Yes.....ANY B-series trans will fit any B-series motor. As long as you need a hydraulic transmission.....you are god to go.
  4. oopadoo
    oopadoo New Member
    I heard input shaft sizes could be a problem between jdm trannys and usdm motors
  5. CAFROG
    NOR-CAL
    Never did it myself but I know it has been done. I do not think there is a difference in their compatibilities.
  6. oopadoo
    oopadoo New Member
    The deal was a no go. Guy put his foot in his mouth. I did however find a gsr tranny. Will that bolt right in to existing tranny mounts on my ls
  7. oopadoo
    oopadoo New Member
    By the way, that wasn't t you, but the guy I was ging to by the b16 tranny from.
  8. CAFROG
    NOR-CAL
    Yes.....it will fit.
  9. GlassHeadlights
    Calgary, AB
  10. oopadoo
    oopadoo New Member
