b16 trans vss sensor help
Discussion in 'HYBRID -> ED-EF / DA' started by HATCHET_HONDA, Jan 24, 2008.
  1. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    so im swappin a b16 into my newly aquired 90 dx. i was wondering how the speedo cable would attatch onto the b16 trans . does the vss still use a driven gear like the cable does? i was thinkin that the only differernce would be that the vss is electrical and the cable is mechanical. works the same eh?
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Yes the VSS is still gear driven. It should bolt up to where the cable speedometer gear was.
  3. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    you're gonna need to get a VSS from a 90-91 integra. the 92-93 integras are obd-1 so i'm not sure if they switched over to the electrical ones for those years.
  4. HATCHET_HONDA
    hobart, indiana
    would i still have to use the vss? i was thinkin that the speedo cable would fit right where the vss is located on the b series trans. so it would work just the same righ? its still drivin the gear for the cable
  5. K2e2vin
    Raleigh, NC
    Yes, it'll still work. From what I've seen, the VSS's from 88-00 Civics and 90-01 Integras are pretty much interchangeable(cable and electric; they bolt up the same)
  6. HATCHET_HONDA
    hobart, indiana
    sweet...i was gettin confused there for a bit
  7. B16RacerN2NR
    Moving back West...
    Now i'm confused lol. Are you saying you're not gonna run a VSS at all and that your just gonna put the cable into the hole where the VSS goes?
  8. K2e2vin
    Raleigh, NC
    He wants to run the cable driven VSS unit(what the CRX's have stock) and was wondering if the B and D-series were the same.
  9. B16RacerN2NR
    Moving back West...
    Are you sure you and him are on the same page? lol IDK Kevin, I'm still confused lol
  10. HATCHET_HONDA
    hobart, indiana
    no vss...i was goin to use the cable. wondering if the cable will fit just the same as the vss
  11. B16RacerN2NR
    Moving back West...
  12. invisibledemon
    Tn
    you need to look at the vss that is on the b series tranny.
    if it has an electrical plug on it then it is eletronic, you can take of the actual electric sensor and plug the analog cable that is currently on your car into the hole, but it is gonna spit it out, alot.
    if it does infact already have a electronic vss on it, then you will need the one that b16racer linked you to.
  13. K2e2vin
    Raleigh, NC
    When I say "cable VSS" I'm referring to this(attached pic).
    That one is from a 88 DX, and should fit into a B-series transmission.
  14. HATCHET_HONDA
    hobart, indiana
    so itll fit right in the b series trans...cool that is exactly what i was asking. awesome.
  15. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    So did it fit?? Im curious to know.
  16. HATCHET_HONDA
    hobart, indiana
    actually i havent bought a trans yet for my swap.. i was just goin over all the parts and such i needed and started thinkin bout speedo cable issues. but i now understand that the cable driven vss will fit in the trans the same as the newer units.
