b16 turbo help
Discussion in 'Forced Induction' started by civic32958, Jan 18, 2005.
  1. civic32958
    civic32958 Junior Member
    Florida
    i have a b16 w/ 9:1 pistons, and eagle rods. Wanna run 330 injectors, fuel pump, fmu , but i wanna do about 12-14 psi. i dont wanna run a stand alone. is that ok should i have bigger injectors?? etc..what would be good for that setup thanks
  2. pissedoffsol
    won't happen, ever.
    stock map sensor tops out at 10 psi.
  3. b16coupe
    b16coupe Senior Member
    anderson, S.C.
    If you don't use a standalone I guess you will have to use an FMU and check valves so your map sensor will never see any positive pressure.
    As for the injectors, I'm not sure but I think the 330's will be ok with the fmu.
  4. 92civicb18b1
    92civicb18b1 The Trisexual
    i dont know what turbo you're using, but 330 injectors seem kinda small.
    You should definetly look into uberdata, or at bare minimun the AFC hack. I mean the FMU will work but it's defenitly not efficient.
  5. pissedoffsol
    as i said, its not happeneing.
    14 psi + a 12:1 fmu = 213 psi of rail pressure.
    ~45 is stock on most honda cars
    you're asking for problems.
    you need management
  6. evo8
    evo8 Senior Member
    your so smart :D
  7. Cashizslick
    Running an fmu would be a total waste if he already has new internals . . .
