I have researched and researched on which swap to do....Basically, I im down to 2 options and wanted to know which one you guys think is better altogether..I also would like to hit about the 300hp mark.
1. I have a B18b motor and was just going to build it up, meaning sleeve it, put in JEpistons, rods etc and do a whole head job replacing all internals with a ferrea valve train...Then of course throwing on the turbo and thats it....
OR
2. Swapping a B16 motor( maybe the stroker motor) into my 94 teg and doing all the same things that I said from above so it can handle the boost...
Question is which motor is best and also which tranny should I use in my car...should i change over to a Type R or GSR tranny etc...If you guys have any better suggestions on swaps let me know...I want to do it right the 1st time...
thanks guys
orosco
OR
thanks guys
orosco
