B16 vs GSR Head Flow
Discussion in 'Engine Building' started by pissedoffsol, Sep 30, 2002.
Thread Status:
Not open for further replies.
  1. pissedoffsol
  2. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Wow I never knew the b16 had more flow at mid range! How reliable is the source if that info b?
  3. slohnda
    slohnda Senior Member
    Sierra Vista, AZ
    gsr head is :owned:
    well, barely. i bet people still debate the flow characteristics of the two, and one being better than the other. doesnt really seem like it matters which you have.
    but which one responds better to mods?#@
  4. pissedoffsol
    its about as reliable as it gets... its from a head porter company.. stock, same day- they have a cfm tester thingge.. they do heads, thats why they have that
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    either way you look at it they both have good flow.. i mean the gsr owned the b16 on the bottom, but the b16 has mid, but the gsr has a bit more near .5
  6. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    Just so you guys realize this, that is the flow properties at cam lobe lift values.
    the low flow is when the valve is just opening, and then as it opens further, the higher end of this graph comes into play.
    AKA, a GSR head would be better for a higher revved engine than a B16a head, BUT a ITR head which is a b16a with a MILD port and polish job would OWN a b18c1 head, fo sho! B)
    Did I mention I'm still running a stock head? OHHHH 1200 in head and valve work will be WELL worth it on my new turbo soon ;)
  7. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Which B16 head did they test? Are all B16 heads the same? Did they only test one of each kind of head? I think that the data presented has too many variables to take as a rule. Are the differences between the flow rates small enough to be attributed to a possible miscast head? They don't really tell you much about the control of their experiment so you can't trust their data.
  8. pissedoffsol
    pretty sure it was an SiR 2 and an obd 1 GSR
  9. Slo86GT
    All b16a port designs are the same. Things such as casting flash and stuff weren't really taken into account, they were STOCK so they just did this as "typical" results I'm sure.
  10. lsvtec
    But they cannot be given as typical when they only used one GSR and one B16 head. All that told me was that the GSR head they used flowed better than the B16 they used. If they tested several of each head and in most of those tests the results were similar to the ones they posted then they could call them typical.
  11. dubster99
    dubster99 Member
    Yes an ITR head would flow better than a GSR, but port the GSR head and it would flow better up top than the ITR head. Stock b16 vs. stock GSR, you won't notice the flow difference in your car.
  12. SixtySecondAssassin
    Austin, TX
    the heads arent cast are they? i thought they were cut from blanks.
    2 cfms dont make much of a difference on small displacement engines. i say get whichever one is cheaper.
  13. paragus
    paragus Senior Member
    i think it all basically comes down to prefrence and budget.
  14. dubster99
    dubster99 Member
    You know you'd probably get better results from the GSR head's smaller combustion chambers resulting in slightly higher compression
  15. lsvtec
    The point was testing one of each head is far from meaningful. The scientific method won't fail. They need to try more than one of each head before the results can be called conclusive.
    Mis-cast, or mis-cut the point is the same.
  16. pissedoffsol
    damn i didn't think this would cause this much arguement :) :sleep:
  17. lsvtec
    These results were posted before the crash, I made the same arguments against taking them as fact then. I don't think that the GSR head has to be better or vice versa, but I want to see someone conduct a meaningful test. These guys tried one of each head and then assumed that all other GSR or B16 heads would produce similar results.
    <insert="Logic Professor"/>
  18. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    TTT, this was a recent debate between some of you and I hope you get some answers from it, and yes it's valve duration.
    Milan
  19. lsvtec
    Aaaaaaaaa!!!
    It's the thread that wouldn't die!
  20. rollwithsoul
    rollwithsoul New Member
    Hey guys, I am super new to this and have purchased about a month ago a 1995 Del Sol. I've wanted one for about 2 years and now that i have one, it has had an engine swap to a B18B1(LS) I presume. It came like that and i have big plans for this car. Now to take off the LS head that's on it (which is not a VTEC). which should I put on the block? Which would be better for the LS/VTEC setup? (I do plan to make it forced induction) b18c1? GSR head? or b16a? :confused: Any info would be appreciated.Thanks
Thread Status:
