When going B16 Sir1 in 91 Si, should you keep the original Si harness and plug everything on the B16 i.e. alternator, sensors, injectors to Si harness plugs? Or just plug the big round connectors? I know you have to add wires but for the rest what is the best way? For example the wires going towards left hand side over the injectors to the injector resistor dont use the same plugs as the Si (B16 has more).
Thanks for any info,
