b16 won't start, need input
Discussion in 'HYBRID -> ED-EF / DA' started by wiredjosh, Sep 12, 2004.
  1. wiredjosh
    wiredjosh Member
    loovull, ky
    Hey all, I have a b16a in a 90 DX hatch that won't start. I have checked and double checked everything, but it's just not happening. I have spark, I have compression, I have even used a NOID light to make sure that the injectors are getting pulses from the ecu. I have done the DX-MPFI swap lots of times, so I know that's all wired up right, the car's just not starting. Does anyone have any ideas?
    The last thing I could think of was that the TDC sensor wires were crossed, since they are always so faded, so I tried switching those around, but with no success. I double checked the timing belt, so I know it's in timing. I checked all of my wiring connections, so I know that they're ok, and I double checked my distributor sequence, firing order, etc. I also checked my grounds. Is there some stupid thing that I'm missing? I am getting no codes off the ECU also. If anyone has any ideas, I could sure use 'em.
    Thanks in advance! :doh:
  2. Johnnylawless
    Johnnylawless Senior Member
    Squirt some fuel into the throttlebody and if it starts you know it's a Fuel issue.
    thencheck your fuel pump fuse
  3. wiredjosh
    wiredjosh Member
    loovull, ky
    I tried that and I know it's not a fuel issue. I also burped the fuel line and bled the pressure regulator. Any other ideas?
  4. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Banana in the tailpipe :)
    No, but seriously, recheck the ignition timing. If the motor cranks, and you are getting fuel and spark, you should be able to turn it over if the ignition timing is right.
  5. Johnnylawless
    if you have fuel, then check for spark
    EDIT: Pull your plugs and check for spark, have a friend turn it over while one plug is grounded to metal
  6. g24jr
    g24jr Member
    MCMINNVILLE, OR
    do you know if the engine even runs. did you have it in a another car or by it from someone?
  7. wiredjosh
    wiredjosh Member
    loovull, ky
    I don't know if the engine runs, but I did buy it from an importer that I have used lots of times before. They have always delivered good engines to me, and they compression and leakdown test their engines before they sell them, so I don't think that's a worry.
    I have checked/tested for all of the following, with good results:
    spark plugs on the valve cover
    noid light on injectors
    continuity to the injectors
    continuity to all distributor wiring
    distributor wiring pinout
    power to resistor box
    grounds
    compression
    injector order at ECU
    Firing order
    tested ECU in another car
    swapped out main relay for a known good relay
    checked all fuses/fusibles
    I have also disconnected both the fpr and fuel filter, and they are both pressurized.
    I also rechecked the timing, and I know that the timing is good.
    If I have spark, there's really no worry about the internals of the distributor, right? I'm seriously out of ideas.
    Tonight I'm going to swap out the injectors altogether, just in case they're not actually flowing, but I don't think that's a problem since I can smell gas after cranking it for a few seconds. If you have any other input for me, I would be happy to hear about it. Hit me up on AIM (wiredspeedjosh) or email me at josh@wiredspeed.com if you have any ideas for me!!
  8. wiredjosh
    wiredjosh Member
    loovull, ky
  9. CReX123
    CReX123 Senior Member
    Well, It could be a few problems......
    Check to MAKE SURE if there is a ground connected to the thermostat housing, thats probably it.
  10. CReX123
    Ya, sorry I spaced out and forgot to finish my reply, SO ANYWAY.....
    Ya, definately try that thermostat housing, That is a major ground that is needed for the car to start and run good.
    Check the MAIN RELAY, that could be it.
    What kind of ECU are you running, That might be it.
    Check the 50AMP fuses that are under the hood in the fuse box, one of those might be blown.
    Does the motor Crank????
  11. wiredjosh
    wiredjosh Member
    loovull, ky
    yes, the motor cranks
    yes, i have checked all the grounds about forty times.
    i replaced the main relay with one that was known good, out of my running crx
    running a pr3 ecu.
    checked every fuse in the car, none blown.
    any other suggestions?
    also, i just pulled the timing cover back off and checked the timing, and it is DEAD ON.
  12. wiredjosh
    wiredjosh Member
    loovull, ky
    yeah, there's gas in the tank! i already thought of that...
    i have no pinched fuel lines, and have fuel pressure both at the banjo bolt and the fpr, as well has having already tested injector signal with a noid light. I can also smell fuel coming out the header after a few seconds of cranking, so I'm certain that it's getting fuel delivery. I don't know how good the fuel filter is, but it's letting gas thru.
    yes, it cranks fine but will not run.
  13. bryan
    bryan Member
    have you pulled the fuel rail and held in the injectors to see them fire they may be getting the light to blink but the injector could be bad and not firing or clogged or something
  14. j_max420
    j_max420 Junior Member
    when you did the swap did you put a fi resistor in
