B16a Acting Crazy!
mattcalica
k, i swapped in my b16a, and now the thing is just bogging like crazy. the timing is all good, but something else is messed up. the car idles at 3 grand and when i floor it, the car does absolutely nothing. i did forget to hook the pcv valve and the map sensor, so could that be the reason the car is running so crazy?
Originally posted by mattcalica@Jan 23 2003, 11:12 PM
... i did forget to hook the pcv valve and the map sensor, so could that be the reason the car is running so crazy?
yes, those things are there for a reason, not to just look pretty :)
lol, yah, i knew i had to hook them up, but the thing is the t fitting on the map sensor hose broke, so i just tried to run the car without it...i didnt know one sensor could cause so many problems
