B16A and B18C Headstuds?
Discussion in 'Engine Building' started by Johnnylawless, May 2, 2005.
  1. Johnnylawless
    Johnnylawless Senior Member
    Can I use the ARP Headstuds from my B18C5 Head and Block with a B16A and the Type R Head?
  2. Johnnylawless
    bump,
    anybody?
  3. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    You should probably contact ARP...
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    B16A block?
    I read somewhere on this forum B18 studs wont work on B16 blocks because the B16A uses shorter head studs due to the fact the block is also shorter.
  5. sohcslammer
    sohcslammer Senior Member
    Bay Area
    :withstupid:
    ARP uses different part numbers, which to me means - different studs.
