b16a axles into 91 si spindles
Discussion in 'HYBRID -> ED-EF / DA' started by Dark91zc, Jul 23, 2005.
  1. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    are the axles suppose to go in with a fight and is there suppose to be a washer between the axle and hub??because i put the axle in the drivers side hub and it was a bitch to spin. any ideas and what side the the axle with the rubber bushing go on
  2. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    Did u take the dust shield off? It sits behind the rotor between the rotor and the axle, you need to take these off, otherwise the axle will lock up on you. They are a circular piece of metal.
  3. Dark91zc
    Corona,CA
    yeah they are both off i am talking about when putting new axles in. can the axle go to far in??
