Hi, I have a 92 EG Civic Si from Australia. The car originally came with a d16a8 twin cam non vtec 1.6 engine which i took out and swapped in a b16a from a 94 JDM EG6 SiR. I chanegd EVERYTHING from the EG6 frontcut into my civic, including the loom, computer, engine, gearbox, gear linkages, radiator.. basically everything. The car now runs fine with the 170ps B16a but i am considering changing a 1.8litre DC2 Type R engine.
I am curious, i am able to get my p30 b16a ECU rechipped with an aftermarket b18c5 Type R program. If this is the case what do i need to do the swap? Is it as simple as merely changing just the Engine and Gearbox? Do I need to change engine mounts? radiator? etc etc?
Also what is the difference between a B18C5 and a B18C7? Are there any other models for the Integra DC2 Type R engines?
Any suggestions or information would be much appreciated.
Thanks.
Thanks.
