yes it will improve torque and hp but it will be some what of a bitch on reliabuility. u will need to modify the b20 block with a custom vtec oil line etc....but yes, it is a pretty phat swap if u do it right....good luck man
john
john
you are BOTH wrong. you cannot put a vtec head on a b20a block. that block came out of the older preludes and is not compatible with the other b series engines. run far far away from that engine. if you are serious about making a crvtec conversion, get rid of the b20a and get a b20z or b20b.
Originally posted by xtremehondaex@Jan 16 2004, 07:47 AM ya it is. Same as LS/VTEC... its called CR-VTEC, and it will make your car really really fast, speaking from personal experience.
Ludespeed.com used to do the conversion, but it cost alot of $$ because of all the machine work that went into it. I think they stoped doing it because they power gains from it were not worth the cost and work. Anything is possable with enough $$
Why? It is in the wrong place. Please post your topic in the right forums. Hybrid is not for suspension or interior posts. EG is not for EF questions, and so forth.
If you have any questions, please PM the moderator who closed this topic.
