b16a, best ecu to use?
Discussion in 'HYBRID -> ED-EF / DA' started by tegrar, Jan 17, 2005.
  1. tegrar
    tegrar Junior Member
    i have a 93 integra, 5-speed, that i'm swapping in a b16a. what is the best obd1 ecu to use with this motor? p28 or p30. I'm kindof confused on the whole ecu thing right now. If anyone can help, i'd greatly appreciate it. :worthy:
  2. tegrar
    does nobody know the answer to this question? someone here has to know.
  3. brian11to1
    brian11to1 Senior Member
  4. StarBellieAngel
    StarBellieAngel Senior Member
    San Jose, CA
    p30 is what i have. p28 is better for tuning, however... if you're from CA, or you have smog issues, you'll need a p30.
    good luck finding one!
  5. formby
    formby learning in progress
    what happened to the ls block/engine
  6. tm_shinjin_si
    tm_shinjin_si Junior Member
    Use the p28 ecu..I am running it in my 93 si.. With b16a run's great.. But if you all are looking for ecu's contact flashoptions.com and send them an email and they will hook you up..fairly cheap for one aswell..
  7. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    If you're keeping the stock ecu profile, you sould should the p30. If you are going to use EMS program a p28 would better.
