b16a, Civic Dx Swap ALmost DOne, Need Some help, P
markpa
First here are some pics,
We dropped the motor in, had a bit of trouble with the tranny mount, Its good now, I plugged in my vacuum hoses and and wires,
But i ran into a couple porblems,
Pic B and C
, Theres three hose on the right side, one on the top, and two on the bottom(actually its one on the bottom split into 2 where do they go?
Pic D
Theres a hard plastic steel line, on the bottom, which has nothing running to it, I dont kno whats its for or where it goes. Its the shiny line close to the alterantor in the pic
Ive put one of the axles in had to take the dust seal off, but it went in alright,
Ill put the other one tomrrow and shift linkage plus all the fluids, And i shgould be good to go, If i could figure this ^^^^Stuff out.
ANy help you guys can give me thanks in advance.
PS. I was also told i had to cross 2 wires wires inside my car, cause it was an auto??
Modified by markpa2 at 5:45 AM 6/20/2004
hmm,m well i couldnt find a flash light to check my car but they look like nothing.
just finish up with everything else and if you run itno problems with it come back.
