b16a ecu codes
Discussion in 'HYBRID -> ED-EF / DA' started by ccr88crx, May 6, 2007.
  1. ccr88crx
    ccr88crx New Member
    we just got and 88 crx with a b16a swap running but the v-tec wont work cuz threre is an error code on the ecu the red light blinks 9 times which code is this and if any one knows what to do can you tell me how to fix it? thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    check it again long blinks = 10s fast blinks =1s
  3. ccr88crx
    ccr88crx New Member
    then it would be a 19
  4. AHHVTEC
    Alabama
    it the automatic tranny lock up solenoid vakve
  5. ccr88crx
    ccr88crx New Member
    the car is a mannual but what would code 9 be
  6. AHHVTEC
    Alabama
    code 9 is cyp sensor not valid for trottle bodied cars,, you might have a automatic ecu
  7. ccr88crx
    ccr88crx New Member
    i have two ecus ill have to try the other
    wound you happen to have a chart that would tell me all the codes for b16a, 5 speed
  8. AHHVTEC
    Alabama
    yea but it would take a long time to type it up but the same chart is here on this very form try the search
  9. ccr88crx
    ccr88crx New Member
    thanks for the help, i'll probably run into more problems hope to use you in the future like the quick replies
  10. ccr88crx
    ccr88crx New Member
    i went back over the codes and i came up with these three 6,9,10
    but they say that nine is not a valid code, so do you just ignore it, and if not how do you get rid of it
  11. ccr88crx
    ccr88crx New Member
  12. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    WRONG!!! It's not a valid code for Throttle Body INJECTION motors. I.E. DPFI or the toilet bowl motors.
    To the topic starter... check all your wiring and the sensors themselves... here's the list...
    http://hondaswap.com/reference-materials/88-ecu-error-codes-29109/
  13. AHHVTEC
    Alabama
    yup i did leve out the word INJECTION
  14. ccr88crx
    ccr88crx New Member
    well somone has told me recently the the engion is an obd0 motor for japan so would the codes still be the same
  15. AHHVTEC
    Alabama
  16. ccr88crx
    ccr88crx New Member
    all right how do you get rid of code 9, cuz with the code flashing vtec wont work right
  17. ccr88crx
    ccr88crx New Member
    or do we have the wrong ecu
  18. AHHVTEC
    Alabama
    i whould try a diffrent ecu
  19. B16RacerN2NR
    Moving back West...
    dude, seriously, please don't give suggestions if you don't know what you are talking about. I'm sure you know a lot about hondas, maybe cars in general, but it's obvious that you don't know what you are talking about when it comes to this subject...
    ccr88crx - your ECU is fine. Code 9 is a VERY VERY VERY common problem with obd-0 motors. The only way (that i know of) to fix a code 9 is to get another distributor. It's a sensor that usually gets thrown off whack or demagnetized in the shipping process. If you open up the distributor, you will see the magnetic sensor i'm talking about.
    Anyway, swapping out your ecu won't help the code 9. Did you get your motor from hmotorsonline.com? if so, call steve and let him know you need a new distributor because the one he gave you is faulty and he'll gladly trade you a good one for your broken one. If you didn't get your motor from there, go here Distributor King : Andale Stores : JDM Distributors and buy a new one. It's kind of pricey but it's well worth it... goodluck :thumbsup:
  20. AHHVTEC
    Alabama
    your right i do know alot about hondas and cars in genral but who said it was a obdo motor,so are you saying there no way a bad ecu could do that, just because someone said it was a obdo dont mean it is i would double check to make sure
