Whats up all. Question here about axles.
I've got an EF3 Si Sedan (Japanese Import) now it was originally running a ZC as you will know. But I bought an EF8 CRX SiR for the B16A and all the running gear which is now in the sedan. Now i'm using all the CRX axles but the driverside shaft (car is RHD) is slightly too short the bearings just about sit into the cup on gearbox and on full lock one of the bearings will sit halfway out of the cup. So could someone tell me what axle I need exactly, or if theres anything I can do to sort out the problem. I'm also using Innovative Mounts.
Thanks Brian
Thanks Brian
