B16A Engine Light
Discussion in 'Civic and del Sol - EG and EK' started by JDMDelSol, May 7, 2008.
  1. JDMDelSol
    JDMDelSol New Member
    Battleford, Sask
    Alright, so im kind of new to this site so take it easy. I have recently bought a 1992 JDM Honda Del Sol and its a beauty, but i'm starting to run into some minor troubles. For one, my engine light continues to turn on after i hit vtec. I was told it was my O2 sensor which i replaced and still face the same problems. I am also starting to hear a squeak coming from the engine around 2-3000 rpm's but it stops when i engage the clutch. I'm not mechanic but im guessing its a belt of some sort. If You can hit me with some adivce it would be greatly appreciated. Thanks.
  2. BrutalB83
    Rochester Hills, MI
    Have you tried actually figuring out what the error code is? Just telling us that the CEL is on isn't going to get you anywhere. Take the car to AutoZone and have them plug in their diagnostic tool and tell you what the light actually means, then we can help you...
  3. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    I don't think that will be possible, being its a 92 jdm del sol.
  4. JDMDelSol
    Battleford, Sask
    To tell you the truth i have tried taking it to a mechanic, and he knew exactly as much as i did about the car. But roughly where abouts would i find the diagnostics plug in
  5. BrutalB83
    Rochester Hills, MI
    Does that mean it's incapable of having codes read? The car should be OBD1, correct?
  6. LS_VTEC
    NJ
    Yes, it is actually impossible to read the codes from a jdm ecu. :)
  7. JDMDelSol
    Battleford, Sask
    I have read in other threads that you can find a blue plug under the dash which can be used to read the ecu. true?
  8. LS_VTEC
    NJ
    There is no diagnostic port on obd1 del sol's, therefore no scanner can just be "plugged in". Also, the ecu's arent the same as the usdm del sol ecu's.
  9. LS_VTEC
    NJ
    If the vehicle is obd2, yes. Obd1, no.
  10. BrutalB83
    Rochester Hills, MI
    Yeah, I couldn't tell if you were being sarcastic or not... :D
  11. LS_VTEC
    NJ
    Brutal, come on broooooooooooo
    Its obd1... you should know this, mannnnn. :)
  12. JDMDelSol
    Battleford, Sask
    so then how does one find out wtf is wrong
  13. LS_VTEC
    NJ
    You better find someone who speaks Japanese and call a Honda dealership in Japan. :)
    Seriously though, keep searching. Without knowing the code or being there in person, I cannot really pin point the cause/s. Good luck though....
  14. JDMDelSol
    Battleford, Sask
    alright, well thanks anyway
  15. LS_VTEC
    NJ
    Good luck on your journey....
  16. BrutalB83
    Rochester Hills, MI
    So is this a true Japanese Del Sol? Like CR-X stickers, left hand drive, power roof, all that good stuff?
  17. efhondakid
    Akron-Canton, Ohio
    Fixed that for you, and power roof? WTF?:confused: How does that work?
  18. BrutalB83
    Rochester Hills, MI
    :lmao: Ha, good call! Had a dumbass moment there...
  19. JDMDelSol
    Battleford, Sask
    Yea man its the real deal. Its a targa top with crx marked all over it. Its a beauty when its working but when its acting like this it just disappoints me.
  20. LS_VTEC
    NJ
    No power moonroof, it has a targa top.
