b16a engine mounts ? avid - hasport ?
loverboy
Hi !
I need engine mounts for my ek 96 coupe into b16b or a.
I saw hasport and avid racing mounts, which is better ? the avid set comes with 5 mounts (tranny too) ?
Is there standart mounts for the swap like the si 99 mounts that can fit ?
Thanks !
Why the hasport is prefeable then the original si mounts ??
I believe the si used mounts cost much less then hasport (300-550 $ 2 ekstk)
The HASport mounts will be made from billet aluminum and be lighter and stronger than the OEM Si mounts, plus they will have polyurethane inserts instead of the OEM flimsy rubber. If you want to use the Si mounts, it's still a very good path to take, and it's MUCH cheaper.
