b16a firing order??
Discussion in 'General Tech and Maintenance' started by integrab16a, Jul 6, 2008.
  1. integrab16a
    integrab16a New Member
    I need a little help. :(
    My first question is: what is the firing order for a b16a? My ecu was stolen out of my 97 Integra awhile back so now I'm running the b16a with a 97 LS ecu. i pulled it out of the gaurge it was running fine and all of a sudden it just died on me i tryed to restart it imeditly it would not fire up it just sate there and cranked over and over and would not fire over can anyone help
  2. the.original.kermit
    the.original.kermit I know everything
    Hamilton, MI
    If it ran good in the first place, it's probably not the firing order (But I'm guessing it's 1-3-4-2, you can also check it yourself by finding tdc looking at the rotor and the distributor)
    Check the 3, fuel, compression, spark.
    You should have compression if it ran right before. Look for spark and fuel (Make sure that you actually have gas in the tank, you would be surprised as to how often people run out of gas and don't know it). Checking your fuel pressure wouldn't be a bad idea (you should also hear your fuel pump kicking on)
