B16a Four Wire O2 Sensor
Discussion in 'ECU's, Electronics, and Tuning' started by simonc, Jan 30, 2003.
  1. simonc
    simonc Member
    Just transplanted a B16a into an EG civic using an OBD1 P30 ecu.
    Problem: the car came with a one wire o2 sensor, the B16a needs a four wire sensor= CEL is on and idling is messy. I know that two wires go to the ecu pins A6 and D14. Does anyone know where the other wires need to go. OR is there a way to fool the ECU in thinking we have a four wire sensor and keep the original one wire one?????
  2. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    i had the same problem, i gave up and took it to get it wired.you screw wiring up and you will be hating life.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Contact DC Sport's they will make you one it cost $29.
  4. SixtySecondAssassin
    Austin, TX
  5. simonc
    simonc Member
    What do DC make? Something that fools the ecu, or a four wie o2 sensor??
