B16A fuel problem NEED HELP BEFORE I LOSE IT!!
Discussion in 'HYBRID -> ED-EF / DA' started by CRXproject, Apr 20, 2004.
  1. CRXproject
    CRXproject Junior Member
    cheyenne, WY
    :blink: Hello i did the b16a swap into my 89crxSI and it seems that the reason i cant get it started is because fuel is not delivering into the block. i Change the main relay and the resistor box. The computer is a pr3 and its throwing a code 8 so it works. the only way i can get it started is by putting fuel in the inside of intake manifold and it will run until that is al burned up. I have spent many nights up trying to fix the problem its enough to lose my head i need help please.
  2. hybrid89
    hybrid89 thistownsucks...
    SoCal
    did you cahnge your fuel filter when the swap was done?
    matt
  3. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    Check you injector resistor box, and are you throwing any codes?
  4. CRXproject
    cheyenne, WY
    Yhea i change both the resistor and the filter, i also changed the main relay. How ever the guy the owned the car before me did put a turn off switch on the hood i know you have to run wire to turn of the fuel. Any ideas???
  5. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    once i did a swap and ALL 4 injectors wouldn't spit out any fuel...you might want to try that, unless the injectors them selves aren't getting any power at all
  6. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    yeah check the current of the fuel injectors, they should pulse if they are getting power, also check the map sensor, my friends car had a similar problem, had plenty of spark but no fuel, switched the maps and wah lah!
