b16a help with pic?
Discussion in 'Civic and CRX - EF' started by evo8psi23, Jun 29, 2008.
  1. evo8psi23
    evo8psi23 New Member
    hey ok crx with a b16a swap i had a diffrent tranny put in and this wire is disconnected it wont plug in no matter how hard i push i was wondering what wire it is my vtec works fine and no ecu codes but the temp gauge dosnt work it used to before the swap so i was wondering if that was the temp wire thanks
  2. evo8psi23
    better shot
  3. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    That's the vtec pressure switch. Either it's making a good enough connection to let vtec activate or your computer is chipped to bypass the need of the pressure switch to activate vtec like you would find in chips such as mugen and skunk2...
