B16A Idling Screw Adjustment
Hi ,
Need guiding on how to adjustment the Idlie Screw to make the Air Fuel ratio rich / lean .....
I mean how many turn the idle screw ?
Thank you .
But make sure everything else is adjusted correctly first. I.E. ignition timing, mechanical timing, throttle cable, etc.
